Where's all the coolant going?
Old Jun 5, 2022 | 02:22 AM
RQs2K's Avatar
Default Where's all the coolant going?
Changed my entire rubber coolant hoses recently because many were old and cracked. I performed the Billman method to bleed the system and got very hot air coming out of the vents on a cold start after 2-3 minutes.
Mishimoto radiator is less than 6 months old, there are no more apparent leaks, temp gauge is normal.
I overfill the reservoir slightly above max in case there are a few little bubbles left to sort themselves out.
This was all yesterday. This morning the reservoir is 50% under max.
Car is supercharged and I live in the desert. Ambient temps yesterday and today are a cool 100f. Is this normal or do I still have a leak?
Old Jun 5, 2022 | 05:25 AM
noodels's Avatar
Water expansion,top it to correct level cold check again at cold.Keep checking for a day or 2.
Old Jun 5, 2022 | 07:15 AM
Chuck S's Avatar
Seems normal.
Water expands about 4% when heated from room temperature to 100°C -- normal engine temperature.
With 2.01 gallons of coolant in the engine and using water as a convenient liquid (I'm not chasing expansion rates for 50-50 coolant on one cup of coffee this morning ) that's about 10 ounces. The reservoir only holds 20 ounces.
-- Chuck
Old Jun 5, 2022 | 10:06 AM
Slowcrash_101's Avatar
If you are using silicone hoses expect some evaporative loss.
Old Jun 5, 2022 | 03:53 PM
RQs2K's Avatar
All oem rubber. Not a big fan of silicone.
I'll keep topping it off and monitoring for a few days I guess.
Old Jun 6, 2022 | 07:01 AM
Chuck S's Avatar
Only fill it to the MAX line. No need to add coolant unless it's below the MIN line.
-- Chuck
dave_
Oct 15, 2014 06:16 PM
Vinny_GPW-S2K
Apr 11, 2012 09:44 AM
Assass1n
Jacksonville
Oct 17, 2011 09:44 AM
Spec_Ops2087
May 29, 2010 01:22 PM
Wargasm
Mar 26, 2007 04:12 PM
