cometic 3mm hg failure?
so i just finished installing a cometic 3mm headgasket on my S. so i fired it up and everythig seemed normal. i was getting some white smoke from the exhaust but nothing crazy. it looked normal like when u first start the car but then after 20 min it was still there so i didnt know if it was normal. i turned it off because i knew it needed some oil and when i took off the oil cap it was a little milky.
i used arp head studs and i torqued them to 80ft/lbs using arp moly lube. any thoughts? please help.
here is a vid
youtube
here is a vid
youtube
https://www.s2ki.com/forums/index.php?showt...&#entry11122831
Should have done some research before you went with that combo.
