Common S2000 Problems/Solutions (1999-2009)
crappppp i saw this
AP2 (2004-2009)
Problem: Gear lever pops out of 2nd, 4th or 6th gear
Solution: Replace the countershaft 1st gear and the 2nd gear set. Service Bulletin
Problem: CEL P1172 and/or P2A00 (MY06+)
Solution: Go to the dealer to update the ECM/PMC PGM-FI software. Replace the air/fuel sensor. Service Bulletin
but i didnt see where that cel was just for 06 up because at the top it says 04+
i guess what i really need to know is in getting to a code reader as long as i dont go over 3 or 4 k i should be alright eh? car has oil runs fine. went 500 miles last weekend...now all of a sudden has a cel after she sat in some traffic, i came home, she sat a lil while, started her up and bam my first cel...weeeeee
AP2 (2004-2009)
300, 301 and 302...and as i mentioned in the other thread no over rev from me. however i did read somewhere that previous over revs may not show up for a while...with my luck the previous owner did it, and i get to pay for it...which means im srsly ****d
Since the misfire...
I've had valve adjustment (engine was also checked for damage). Changed pcv valve, spark plug change on misfire cyl. And moved coil around.
I only get a CEL on idle or coasting to a stop.
Im starting to think vacuum leak.
i took someones advice and just reset it...i really think it was just an ecu hiccup...waiting now to see if it comes back...the car runs absolutely perfect, but i still think im going to have a compression and leakdown test done just for peace of mind
