competition clutch guys
i just installed the iron man a week ago, i love the way the clutch feels but its noisy as hell when the rpms are falling in the 5000 to 2500 range, its fine when im on throttle but as soon as i let off it starts buzzing pretty loud, anyone else with a comp clutch experiancing this?
BTW the disc is causing the buzz. The PP is likely ok, but can't be used with a stock disc as it uses advanced friction to achieve it's bite. Hence the soft pedal.
Unlike ACT which uses added clamping force, making it a great companion with the oem disc.
I have a Cusco puck clutch and light weight flywheel and it does not buzz or chatter. Real nice set up, although I would like to go back to the original weight flywheel because this one allows you to fall out of revs to fast under calm daily driving.
riceball777
Jul 14, 2011 07:18 AM
