Complete diagnose on S2000
I need to perform a complete and full diagnostic exam on the mechanical side on an S2000 prior to purchase.
I did a list of what's need to be covered and would like your expertise to make sure i covered all areas.
Engine:
Leak down test.
Compression test.
Check oil for any metal pieces
Check engine mounts for any leaks
Gearbox
Check that all gears come in without the use of additional force on the stick.
Check if the clutch slips or smells
Diff
General
Check shocks
Check bushes
Is there any other suggestions apart from the above ?
I am mostly concerned about the diff.
Engine:
Leak down test.
Compression test.
Gearbox
Diff
General
Check shocks
Check bushes
