Compression
From service manual:
Check at 250 RPM with wide open throttle.
Nominal: 228 PSI
Minimum: 135
Max Variation: 28 PSI
If you checked all of them and they are all fairly consistent with 180-185 then according to the numbers you should be fine. Aslong as there isnt any crazy numbers like 150-200-203-196. If I was in the situation id look to see the service history and look around for any other anomalies. You can take it to a shop and they'll do a 150 point (or whatever is) inspection for a few hundred bucks and they'll look over everything. Definitely worth spending the money vs spending more money down the road. A few hundred is pricey, but gives you piece of mind
Nominal: 228 PSI
Minimum: 135
Those numbers sound fine. Consistancy between cylinders is the important thing to look for. A lot of compression gauges aren't super accurate to the actual PSI. I say buy it, keep up your maintenence and drive it another 80,000km
What compression tester did you use?
I recently purchased a cheap US General from Harbor Freight and it does not have a Schrader/check valve at the tip of the adapter hose that screws into the head, as a result I had additional volume inside the hose that the motor had to compress and got results similar to you. However, I did have 1 low cylinder (165psi compared to 180psi). I redid the compression test borrowing another compression tester which had a Schrader valve at the end of the adapter hose and got readings from 200-240 psi. Not all compression gauges are built equally, but your readings seems consistent across all cylinders so it seems fine. I suggest finding another compression tester to see if you get the same results.
