Compression numbers and plug inspection
Old Oct 23, 2014 | 04:03 PM
daileyboy81's Avatar
Default Compression numbers and plug inspection
I finally got around to checking compression in all cylinders today. I also checked the spark plugs to see what they look like after 1000 miles.
Here's what the plugs look like:
I noticed a mix between a matte black color and some brown?
My compression in order of cylinders 1-4 was 220, 223, 222, 225 at 1,000 ft. above sea level.
It's a 2003 F20C with ~120,000 on the motor (non-original) and 1000 miles on the spark plugs. Does everything look normal? I'm trying to make sure I have a healthy motor to go FI with. Thanks in advance for any help!
Old Oct 23, 2014 | 05:27 PM
windhund116's Avatar
Seems ok. At least the compression number look good. Better photos of the tips of the spark plugs?
Old Oct 23, 2014 | 05:56 PM
Didn't really get the chance to snap more pics of the plugs but if you could imagine the first thread or two is darker and kinda charcoal-ish. you can even see I kinda rubbed some of it off on #3..
Old Oct 23, 2014 | 11:59 PM
Looks mebee a bit rich...
http://www.wallaceracing.com/plug-reading-lm.html
http://www.ngk.com.au/spark-plugs/te...-plug-analysis
Old Oct 24, 2014 | 03:48 AM
tangoray's Avatar
good compression numbers for an engine with 120k on it!
Old Oct 24, 2014 | 06:29 AM
Thanks for those sources! It appears I am running a little rich. I'm sure I can get air/fuel adjusted through a tune by someone who knows about that stuff.
Old Oct 24, 2014 | 10:49 AM
Slowcrash_101's Avatar
This typically happens when you have a lazy O2 sensor, if you're still on the original a new primary would help.
jdblood202
Jun 22, 2014 05:27 PM
s2kbtos
Mar 4, 2013 12:15 PM
S2Krazy
Sep 21, 2008 10:52 AM
heffergm
Jan 16, 2004 10:37 AM
soons2k
Oct 25, 2002 08:46 AM
