compression test and new engine
Old Nov 8, 2015 | 01:17 PM
s2kbtos's Avatar
Default compression test and new engine
I have been doing my compression test every year,since I've had the car. I got the car back in 2007, since then it has been turbocharged almost 2 years and now it has been supercharged for the past 3 years. The first time I ever did the compression test it was high 190's across the board. Last year compression test was high 180's and now I just did one and got 184,171,170,170. The car has 148k miles. It seems that I'll be needing to be rebuilding soon.... at what compression would I need to start worrying about replacing the engine?
Old Nov 8, 2015 | 05:17 PM
fastD's Avatar
Have you adjusted the valves?
Old Nov 8, 2015 | 06:12 PM
s2kbtos's Avatar
Last time it got adjusted was at 100k
Old Nov 8, 2015 | 11:06 PM
HarryD's Avatar
Common sense dictates that your compression numbers are probably fine because they are all *consistent* ... but a lot of the armchair mechanics on here will tell you your engine is about to die because you aren't blowing 240/240/240/240 on all cylinders. The largest variance between 170 and 184 is 14psi (or only 8.2%).
Helms manual:
  • Nominal: 228 psi
  • Min: 135psi
  • Max variation: 28psi
Perhaps try using another compression tester, make sure:
  • Engine at operating temp (hot)
  • Pull all spark plugs out
  • WOT
  • crank each cylinder the same amount (5-7 times)
  • Injectors unplugged
EK9MAX
Jul 6, 2009 11:17 PM
jert534
Jul 18, 2006 06:38 PM
