Compression test results.
Old Jun 9, 2020 | 05:01 PM
klapamos's Avatar
Default Compression test results.
Hey all,
So I found a good deal on a 2005 engine swap. The seller seems legit and answered my many questions well. The car currently has a compression of 240, 230, 215, 220. Test was done cold. The 25 difference is slightly concerning, thoughts. I would think it would be closer with a warm engine. Also can you use an AP1 timing chain tensioner be used with and 2005 AP2 engine?
Old Jun 10, 2020 | 04:12 AM
Slowcrash_101's Avatar
You can have up to 10% variance in compression over ideal values and be fine. So if ideal cylinder compression is 220psi you can be +/- 22 psi and be ok. Ideally the leakdown will tell you more than a compression test will. You don't even need a leakdown tester just a good set of ears.
Old Jun 12, 2020 | 03:36 PM
Saki GT's Avatar
For the tensioners, do yourself a favor and buy one from Billman here - it will last longer and be more reliable.
DanielB
May 4, 2018 12:02 PM
Legal Bill
Mar 25, 2018 02:26 AM
bobrad52
Cars for Sale
Mar 19, 2018 01:12 PM
SilliG
Jun 8, 2016 09:52 PM
