Compression test results
Old Jun 6, 2010 | 04:04 PM
s2kflorida's Avatar
Default Compression test results
I read that 240 is ideal for a our engine compression, but my numbers were significantly lower. At least there were no huge variations. Here are numbers:
Cold Engine
185,170,200,190
180,180,190,190
Warm Engine
195,200,195,190
200,200,197,190
What do you think? My car is a 2000 AP1 with 117k miles.
Old Jun 6, 2010 | 04:28 PM
tizbad2k's Avatar
seems a bit low.
I ran a test today on a warm engine and got 220 220 230 230.
But atleast all your numbers are very close to each other, max variation should be 28psi. Nominal value is 228 and minimum is 135.
Old Jun 6, 2010 | 05:46 PM
s2kflorida's Avatar
Originally Posted by tizbad2k,Jun 6 2010, 04:28 PM
seems a bit low.
What does it mean if my numbers are low?
Old Jun 6, 2010 | 08:10 PM
crank's Avatar
cracked retainers/scored walls/ faulty head gasket/ worn valve springs.......it can mean a number of things really. One must distinguish which of the specific causes it is.
Old Jun 6, 2010 | 08:14 PM
hypforlife32's Avatar
is a compression test of 240,235,240,235 good? ap1 with 65k.
Old Jun 6, 2010 | 08:23 PM
crank's Avatar
yes thats good, kinda high but some guages read differently.
Old Jun 6, 2010 | 08:38 PM
JDMQuip's Avatar
Do a leak down test and see if your numbers are within reason.
Old Jun 7, 2010 | 05:57 AM
crank's Avatar
if doing a compression test might as well always do a leakdown test as well.
Old Jun 7, 2010 | 12:51 PM
Moddiction's Avatar
Former Sponsor
Numbers do seem a bit low. Did mine today on warm engine. I have 128K on it and recently been sc'd.
I got:
224
223
223
224
The biggest concern with a compression test is consistency though.
You want to make sure no cylinders are more than 10 psi difference really.
I also forgot to hold the throttle open so would have been a little bit higher I think but all consistent so that is what I care about.
Old Jun 7, 2010 | 01:36 PM
s2kflorida's Avatar
Hey guys, I was reading the tutorial DIY again and realized that I didn't hold open the throttle while I was cranking. Would this give me lower numbers?
I'll try again this afternoon with the throttle open this time and let it warm up longer. Maybe I'll have better results.
