Compression test results
Old Jun 7, 2010 | 01:50 PM
Moddiction's Avatar
Former Sponsor
I actually just realized I forgot to do that this time as well. But the numbers I posted were without the throttle opened so those still seem low but worth a shot checking again if you want.
Old Jun 7, 2010 | 01:56 PM
Disgustipated's Avatar
Originally Posted by Moddiction,Jun 7 2010, 01:51 PM
Numbers do seem a bit low. Did mine today on warm engine. I have 228K on it and recently been sc'd.
I got:
224
223
223
224
The biggest concern with a compression test is consistency though.
You want to make sure no cylinders are more than 10 psi difference really.
Wow! 228k miles and still running strong... That is awesome.
Old Jun 7, 2010 | 01:57 PM
Moddiction's Avatar
Former Sponsor
oooppss lol. 128K my bad haha
Old Jun 7, 2010 | 04:04 PM
s2kflorida's Avatar
Ok well check this... I ran it again and got 200 - 205 across the cylinders. Minor improvement. I did the "tablespoon of oil on the cylinder" trick on the first cylinder and got 240!
I read that this means my O-rings are leaking causing blow-by. If it was the cylinders that were damaged, then the tablespoon of oil wouldn't have worked right?
So to repair this requires an engine rebuild to replace the O-rings? One guy recommended I put "Restore" in my oil and it might help restore my O-rings?
Has anyone tried this?
Since my numbers are pretty much the same across the board, do you guys think this is ok?
Old Jun 7, 2010 | 04:46 PM
Moddiction's Avatar
Former Sponsor
Yeah i think it is ok. Will just be a slightly lower compression engine. When 1 cylinder is waay off then you know you got another issue going on with that one cylinder. Like a scored wall or bad gasket etc. I wouldn't worry about it too much.
Old Jun 7, 2010 | 05:47 PM
s2kflorida's Avatar
Ok, I'll just accept that my engine won't be at 100% unless I rebuild it.
Thanks for everyone's answers.
Old Jun 7, 2010 | 07:07 PM
s2k dre's Avatar
I wouldnt worry about ur numbers. As long as it doesnt smoke or burn oil dont rebuild it just yet.
jungle
Mar 5, 2019 09:18 AM
s2kbtos
Nov 8, 2015 11:06 PM
BEASTMODE
Oct 19, 2011 09:01 PM
Phil H
Jun 21, 2005 07:14 PM
