Compression test, then more problems!
Old May 13, 2014 | 04:04 AM
SMG1990's Avatar
Default Compression test, then more problems!
Has anyone had experience with faulty injectors?
I had my compression tested which were averaging at about 180 across all 4 cylinders.
This led the mechanic to find that all the spark plugs were extremely old (car serviced by Honda in December) and one of the injectors is not spraying where it should be which could aparently cause damage to the pistons after a while, has anyone else experienced this?
Old May 13, 2014 | 09:22 AM
Gotpepsi's Avatar
My car had faulty injectors that caused a misfire, MY01 93K at the time. I replaced the injectors with 4 new ones and the problem was solved
Old May 14, 2014 | 04:32 AM
SMG1990's Avatar
Just got the car back, turns out the compression reader was faulty and they retested and was getting between 220-240 in each cylinder.
All the spark plugs were worn down and one of the injectors needed to be refurbished.
Dyno test to be done tomorrow
flyingtoaster
Nov 13, 2010 05:38 AM
ckim715
Mid-A Swap Meet
Jan 16, 2009 11:24 AM
AusS2000
Feb 15, 2007 08:00 PM
driftnby
Nov 23, 2005 12:50 PM
demonderrick
Apr 2, 2005 01:31 PM
