Comptech adjustable springs PROBLEM
Hey guys, i have a MY01 S2000 and had just purchased some comptech adjustable springs ( http://www.comptechusa.com/instructions/ins061.pdf this is a pdf file from comptech
Originally Posted by ImportSport,Jun 2 2005, 06:23 PM
did you check to make sure you reseated the dust covers and associated suspension pieces properly?
Is the sound specific to the left or right of the car?
and thanks for moving it, im a newb...
Make sure you tightened all the bulljoints to your sway bar 100%. I missed one when I did my suspension, and I got a popping noise. These are tricky to tighen because of the fact that sometimes the bolt will want to turn with the nut. In which case, you have to use a low profile wrench and a pair of pliers to hold on the bolt.
And yeah, like they said 2.5" is crazy...
Originally Posted by kw2000,Jun 3 2005, 08:05 AM
not sure if u gotta do this with s2k but i had to with my prelude did u cut the bump stop in half? because if u lower it and dont youll be hitting it
and yes i know 2.5 is too low, but i just wanted to test them out since they were "adjustable springs" not lowering springs or coilovers. and if the popping is coming from being too low i will feel like an idiot!
