Comptech adjustable springs PROBLEM
Old Jun 2, 2005 | 06:00 PM
NomiAP1's Avatar
Default Comptech adjustable springs PROBLEM
Hey guys, i have a MY01 S2000 and had just purchased some comptech adjustable springs ( http://www.comptechusa.com/instructions/ins061.pdf this is a pdf file from comptech
Old Jun 2, 2005 | 06:23 PM
ImportSport's Avatar
did you check to make sure you reseated the dust covers and associated suspension pieces properly?
Is the sound specific to the left or right of the car?
Old Jun 2, 2005 | 06:38 PM
Slows2k's Avatar
Moving to UTH, Technical is for Detailed instructions/procedures. You'll have more exposure in UTH and more responses.
Old Jun 2, 2005 | 07:10 PM
NomiAP1's Avatar
it says not to re-use the stock dust covers... and it is specific to the drivers side...
and thanks for moving it, im a newb...
Old Jun 3, 2005 | 06:26 AM
TubeDriver's Avatar
Recheck the torque on all your bolts. Make sure to preload the suspension before torqueing the bolts. 2.5 is pretty low considering how soft those springs are.
Old Jun 3, 2005 | 07:45 AM
glagola1's Avatar
2.5"!!!! Damn.... That's too low for any car that is driven on the street IMO.
Raise it.
Old Jun 3, 2005 | 08:05 AM
kw2000's Avatar
not sure if u gotta do this with s2k but i had to with my prelude did u cut the bump stop in half? because if u lower it and dont youll be hitting it
Old Jun 3, 2005 | 08:33 AM
arcadence's Avatar
Make sure you tightened all the bulljoints to your sway bar 100%. I missed one when I did my suspension, and I got a popping noise. These are tricky to tighen because of the fact that sometimes the bolt will want to turn with the nut. In which case, you have to use a low profile wrench and a pair of pliers to hold on the bolt.
And yeah, like they said 2.5" is crazy...
Old Jun 3, 2005 | 08:40 AM
METATRON's Avatar
Yes he IS your president
Old Jun 3, 2005 | 10:44 AM
NomiAP1's Avatar
yes i did cut the bumpstops in half but only in the rear's because on comptech's installation it says not to modify them at all...
and yes i know 2.5 is too low, but i just wanted to test them out since they were "adjustable springs" not lowering springs or coilovers. and if the popping is coming from being too low i will feel like an idiot!
