Comptech and BOV non aftercooled??
Old Jan 6, 2004 | 05:50 PM
Jip69's Avatar
Default Comptech and BOV non aftercooled??
I know the aftercooled supercharger kit can have a BOV but can I add one to the non aftercooled version? I noticed in the black tube from charger to intake has a bypass valve in it......I asked comptech and they have never tested it.....
JP
Old Jan 6, 2004 | 06:52 PM
AusS2000's Avatar
Sure it can. Just attach it to the aluminium L bend. Will take some fabrication though.
You'll also have to block the tube leading to the intake pipe.
Old Jan 6, 2004 | 07:38 PM
Jip69's Avatar
I was thinking it would connect right to the L tube, but what do you mean by blocking the tube from the intake.....thanks
JP
Old Jan 6, 2004 | 08:12 PM
AusS2000's Avatar
The stock system is simply a hose between the pressuried L pipe and the rubber intake tract with a bypass valve inline (near the intake). If you remove this assembly you need to find a way to attach a BOV to the pressurised L pipe (some fabrication of a flange would be the preferred method) but you also need to block the hole where the bypassed charge air returns to the intake tract as under boost it will be sucking unfiltered air in. A small rubber bung and a hose clamp will do the trick.
Old Jan 7, 2004 | 05:24 AM
Jip69's Avatar
Alright now I see what u mean. I didnt ever notice that it connected like that. Thanks for the info
JP
Old Jan 7, 2004 | 07:11 PM
Tech2Drew's Avatar
If you need a BOV i'm doing a GB on the Turbonetics Godzilla BOV. Call me if you are interested (800)59TECH2.
Drew
nightcrawler7188
Feb 24, 2008 06:57 AM
yellowknockers
Dec 15, 2004 01:51 AM
AusS2000
Feb 9, 2004 11:46 AM
kevsS2
Jan 29, 2004 10:22 PM
AusS2000
Jan 29, 2004 04:57 PM
