Comptech Intake Rattle
Old Jan 31, 2006 | 11:57 AM
MULDER's Avatar
Default Comptech Intake Rattle
For those Comptech Icebox owners out there...
I have this nasty sounding rattle coming from the intake. I am pretty sure it is because the icebox (notorious for non-exact fitment) touching the hood, causing the hood to amplify the rattling sound and vibrate at the 5K range. I have since placed a small piece of padding on the tab that rubs the Icebox, and that has help a little.
I was wondering what other solutions some of my fellow owners have come up with.
Thanks in advance!
-Mulder
Old Jan 31, 2006 | 11:58 AM
MULDER's Avatar
BTW.... the Comptech rules!
Old Jan 31, 2006 | 02:25 PM
MULDER's Avatar
Help????
Old Jan 31, 2006 | 02:29 PM
Slows2k's Avatar
Push down really hard on the air box to crush the AC lines insulation. Some foam tape on the hood seems to help as well.
Old Jan 31, 2006 | 02:48 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Make sure the box is sitting all the way down, touching the two ribs of the cross member.
If not, you need to re-route the wiring harness. On the rear box mounting bracket, there's a wiring harness on top of it. Remove the mounting bracket, and move the harness below it.
Old Jan 31, 2006 | 02:52 PM
Slows2k's Avatar
Forgot about the wiring harness.
The 3 different boxes I've dealt with all fit equally bad. (1 V1, contoured top, 1 roto-molded plastic with a smooth top V2 , and a fiberglass boxed, smooth top V2)
Old Jan 31, 2006 | 02:54 PM
Billman250's Avatar
Top Answer: 1
Of all the Comptech boxes I've done, the box directly hits that harness.
Old Jan 31, 2006 | 02:59 PM
SC_Highlander's Avatar
If it's just the top vibrating, try this: https://www.s2ki.com/forums/index.php?showtopic=337273
Old Jan 31, 2006 | 05:18 PM
CypherAZ's Avatar
sell it and buy something else.
Old Feb 1, 2006 | 04:28 AM
MULDER's Avatar
Thanks Brian, I'm gonna try that today. Cypher your crazy!
Ok, next question; what is the best filter to run in a Comptech?
