i am planning to add a fuel pressure gauge to my car.
The car is equipped with a Comptech SC + Aftercooler.
Is their an easier way to install a fuel pressure sensor except drill and tapping it into the fuel rail?
I was thinking about a T-Adaptor between the fuel regulator and the comptech fuel line, is this possible?
If I was going to install a gauge on mine, I would tap the end of the fuel rail and use a liquid filled gauge. Yoy could use a gauge adapter on the AN lines pretty easy with the Comptech FMU. It depends how much room you have around the FMU.
Just found a pic from Speeeding (Command Flo install).
It seems that this adaptor should work, but where can i get such a thing. And is it also possible to fit an DEFI-Fuel Pressuro Sensor instad a liquid gauge on this adaptor???
Questions over questions..... hopefully someone can bring some light into the shadows
PS: This pic belongs to speeeding, i hope he has nothing against it, that i posted it on my thread.
Does the fuel rail end of the Comptech hose unthread from the banjo fitting? If it does you can use 6AN adapters to put a Gauge fitting inline. If the fuel rail end is one piece, you can make something up like speeding has done.
www.summitracing.com can get you just about any AN fitting and gauge adapter you need. Aeroquip, Earl's, Russell, and Summit all make adapters and fittings.
