Rook leaks into trunk
Old Mar 28, 2004 | 12:54 PM
sagejester's Avatar
Default Rook leaks into trunk
I am facing a serious water leak from under the rear area of the convertible top, on the passenger side. Has anyone experienced this? I am beyond the warranty on my '01, and would love a suggestion.
Thanks..
Old Mar 28, 2004 | 05:31 PM
twohoos's Avatar
Bishop to knight 4?
Old Mar 28, 2004 | 06:48 PM
MidnightDragon's Avatar
Originally posted by twohoos
Bishop to knight 4?
ideugene's Avatar
Bishop to knight 4?
anyway... you should try to pinpoint exactly where the leak is... put a towel underneath and slowly drip water on the top where you think the leak is... once you got it all figured out... then take the next step of figuring out how to solve the problem
Old Mar 30, 2004 | 06:47 AM
sagejester's Avatar
I have identified that the leak is coming from the rear seal in the rear corner of the top on the passenger side. If you look at your S2K with the top partially down you can see a rubber seal that runs from the passenger doo back. This seal ends as the top rounds from the side to the rear. At this end point is where the leak is.
Incorigible
Apr 18, 2017 05:57 PM
starchland
Apr 22, 2014 08:45 AM
markva4
Mar 3, 2014 02:55 PM
termigni
Apr 30, 2010 12:22 PM
shizzl3s
Nov 19, 2008 06:52 AM
