confusing oil leak !
Everytime I pull out of my garage , there's couple of drops of oil on the ground . I checked the valve cover (fine ) , everything viewed from top of the motor (fine), oil pan (fine) , as soon as I threw my hand under the oil filter it was wet oil ! I went ahead and got an oil change , the same thing happened next day . This time I told the guy to really tighten the filter and he did (still leak ) . It's coming from right where the filter connects , right underneath . Can anyone help me with this ?
Maybe the filter is too tight already. I have read that some filter's sealer rings can deform if over tightened. What type filter do you have? You may also have "gunk" on the oil filter's mating surface that needs to be cleaned or scraped off.
What does "hand tight" mean? I ask because a loose oil filter can be hazardous, there are several threads on oil filters leaking at the base causing engine fires when the hot oil was ignited by the exhaust header. Also, overtightened filters can leak. So what's the correct amount? My understanding is to screw the filter on until it just seats on the oil cooler, then tighten it 1/2 to 3/4 of a revolution more. That's a simple, repeatable procedure that leaves no question about correct tightness. As suggested above, clean the seating surface on the oil cooler making sure the sealing gasket from an old filter is not stuck to it.
Also, some filters leak no matter what you do because of manufacturing defects. I've read about OEM and Mobil 1 filters leaking at the base, so even good quality units sometimes have problems.
