confusing oil leak !
Old Sep 9, 2003 | 07:54 AM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by RazorV3
[B]hand tight for me means tightening it as much as you can only with your hand.
Old Sep 9, 2003 | 08:10 AM
davepk's Avatar
the oil filter should be on hand tight, have been doing this on my hondas for the past 2-3 years and never had a problem.
Yup, And neither did I till a hand tightened filter came loose at LagunaSeca and caused an engine bay fire.
I HIGHLY recommend that you tighten the filter with a torque wrench! Safety wire wouldn't be a bad idea either.
Also, If it is the filter that's leaking its likely due to a bad O-Ring seal on the filter, they aren't securely fastened to the filter and can be dislodged if mishandled. You might also have an O-ring from a previous filter that stuck to the base plate and ended up between the new filter and the base plate. Regardless of the cause you should replace the filter yet again and this time witness the procedure for yourself. And then, Never let anyone else but yourself change the oil and filter.
Old Sep 10, 2003 | 08:51 AM
Asura's Avatar
Originally posted by davepk
... And then, Never let anyone else but yourself change the oil and filter.
Oil changes are easy to do, and the peace of mind is worth the 15 minutes it takes.
Old Sep 12, 2003 | 09:13 AM
Fastlane's Avatar
Update - We replaced the O ring on the adapter that the oil filter mounts to and re-torqued the screw bolt . Sure enough , no more leak !
Old Mar 21, 2010 | 02:43 AM
gamgam's Avatar
reviving a really old thread but after my mechanic using some random nissan filter during my last service I am having the same problem with the oil leak around the seal and then dripping down when I start the car. One question, is it possible to change the oil filter without completely draining all the oil from the car or do I have to drain the oil before I can change the filter.
Old Mar 21, 2010 | 10:58 AM
jyeung528's Avatar
Originally Posted by Avi,Sep 8 2003, 09:09 AM
If it is reddish oil than it could be one of your bushings. In my 01 S I had it happen and Honda changed both of them.
what bushing do you speak of? engine mount?
Old Mar 22, 2010 | 02:07 AM
gamgam's Avatar
Originally Posted by isthisusernameavailable,Mar 21 2010, 10:19 AM
Just had this done, filter changed without draining the oil. There was some spillage that has burned off, and had to top off with about a half quart, but it can be done.
Is it safe to change it though, (assuming I clean it properly) I don't want to risk an engine fire.
Old Mar 22, 2010 | 06:45 AM
Sideways's Avatar
Red oil is the rear differential mounts.
Old Mar 22, 2010 | 08:31 AM
CKit's Avatar
Red oil is also the motor mounts if located in the front.
FISH22
Aug 31, 2012 09:21 PM
Tuanster
Nov 20, 2006 07:56 AM
yellafeva
May 13, 2004 01:46 AM
davepk
Mar 3, 2003 04:24 PM
junehhan
Oct 16, 2002 12:52 PM
