Converting EMS map to Kpro
I have a map for an EMS that I'm trying to convert to use with my Kpro and, since I'm a noob, I have some questions. The fuel units are different for each, like they use different scales (i.e. mm vs cm). What do I need to convert the fuel values in the ems map to work as a kpro map? Or is there an easier way to do this that I don't know about. The EMS map is below. Thanks!
http://forum.aempower.com/forum/index.php?...3.0;attach=4155
I doubt there is an easy way of doing it.
Are your breakpoints the same?
I guess you could change the breakpoints in the AEM to match the Kpro and then convert between units. The AEM is pretty flexible in what units it displays in.
Okay. That helps, the map I'm trying to convert is set w/ TPS % for the y-axis. Now what are the values for the fuel amount? Now that I have matching axes in K-Manager and AEM, I need to populate the cells in K-Manager and the fuel units are different. What does AEM use for Fuel units?
