Converting EMS map to Kpro
Old Apr 14, 2008 | 10:44 AM
kial007's Avatar
Default Converting EMS map to Kpro
I have a map for an EMS that I'm trying to convert to use with my Kpro and, since I'm a noob, I have some questions. The fuel units are different for each, like they use different scales (i.e. mm vs cm). What do I need to convert the fuel values in the ems map to work as a kpro map? Or is there an easier way to do this that I don't know about. The EMS map is below. Thanks!
http://forum.aempower.com/forum/index.php?...3.0;attach=4155
Old Apr 14, 2008 | 02:33 PM
AusS2000's Avatar
I doubt there is an easy way of doing it.
Are your breakpoints the same?
I guess you could change the breakpoints in the AEM to match the Kpro and then convert between units. The AEM is pretty flexible in what units it displays in.
Old Apr 14, 2008 | 03:19 PM
kial007's Avatar
I can change the breakpoints in K-Manager to match the AEM but I cannot figure out what units or scale the AEM map is using on the y-axis for the raw fuel map. Any idea?
Old Apr 14, 2008 | 03:56 PM
AusS2000's Avatar
The load axis? That's in Psi or Kg/Cm2 or whatever pressure unit you have chosen.
Old Apr 14, 2008 | 04:35 PM
kial007's Avatar
Okay. That helps, the map I'm trying to convert is set w/ TPS % for the y-axis. Now what are the values for the fuel amount? Now that I have matching axes in K-Manager and AEM, I need to populate the cells in K-Manager and the fuel units are different. What does AEM use for Fuel units?
Old Apr 14, 2008 | 04:47 PM
AusS2000's Avatar
TPS%? That's a bit strange.
The unit for each cell can be several things. 0-255, % duty and something else. Look it up in AEM help.
Old Apr 14, 2008 | 04:56 PM
kial007's Avatar
It's the 0-255 but are the units associated with these values?
Old Apr 14, 2008 | 04:59 PM
AusS2000's Avatar
It represents 0-100% injector duty cycle.
Old Apr 14, 2008 | 05:36 PM
kial007's Avatar
0-255% duty cycle?
Old Apr 14, 2008 | 05:55 PM
AusS2000's Avatar
0=0% duty cycle
127=50% duty cycle
255=100% duty cycle
