Coolant bleeder valve hose
Old Nov 20, 2014 | 07:56 PM
ManOnFire75's Avatar
Default Coolant bleeder valve hose
Hey all
I have question. Just to get on the same page, my 13 year old stock radiator cracked so obviously I had to change it. Luckily no over heat or anything.
But! unfortunately as I was purging the air out of the radiator I happened to break the hose under the bleeder valve with a wrench so I wasnt able to get the air out of the system.
This is probably a rhetorical question but just for the sake of me getting done right the first time I want to make sure this is a heater hose. (THE ONE UNDER THE RED CIRCLE)
Thanks to AusS2000 for the picture I am borrowing,
Also I guess I wont know till I get the hose replaced (dont worry im not driving it) but before I cracked the hose, my heater still wasnt getting hot. I had purged what air I could up until
I cracked the hose. Any ideas?
Old Nov 20, 2014 | 09:33 PM
EVLS2K's Avatar
The heater doesn't get hot because you have air/low coolant in the radiator/engine
After you replace the hose follow billman250 bleeding instructions
Old Nov 21, 2014 | 07:19 AM
would you happened to know what size that hose is?
Old Nov 21, 2014 | 06:16 PM
EVLS2K's Avatar
I have no idea but you can pm billman250 he is a s2k god
Old Nov 21, 2014 | 06:42 PM
fernando.'s Avatar
At work (I'm a honda tech) we use a coolant bucket, pour coolant into the bucket, set the heat to max hot and set the fans to full speed, then let the car idle until the lower rad hose gets hot. The air will bubble out of the coolant bucket and life will be grand.
The coolant bucket looks like this. ~$15 item.
khangaroo
Aug 5, 2016 07:30 AM
Mijae007
Jul 10, 2016 11:22 PM
2001-S2k
Jun 11, 2014 06:22 PM
SpoolinU
Oct 23, 2009 09:33 AM
