Coolant Flush...
Old Jul 11, 2013 | 02:12 PM
EELPIE's Avatar
Default Coolant Flush...
I am getting ready to do a coolant change on my 2003 AP1. Is removing the block drain a must? I have already bought a new block plug and sealing ring. However if it is not really required I would rather not unthread/rethread a plug into the aluminum block. How incomplete will the flush be without removing the plug?
My second question is about the sealer the FSB says to put on the plug. What kind of sealer? Blue or Green Loctite? Liquid or regular teflon tape? The FSB is not clear.
Thanks I appreciate your interest.
Old Jul 11, 2013 | 02:19 PM
sillyboybmxer's Avatar
https://www.s2ki.com/s2000/topic/818714-radiator-flush/
pay attention to billman250 posts.
I did this yesterday.
Old Jul 11, 2013 | 03:38 PM
hatchhero's Avatar
I believe Honda recommends just a drain and fill. That's what ive done on all my Hondas. Jack the car up and loosen the drain plug on the bottom of the radiator. Then take the radiator cap off and let it flow out till empty. I would just go get a gallon of Honda 50/50 coolant. I would fill up the radiator and reservoir (only half way), squeeze the upper radiator hose as hard as you can till coolant comes out the radiator. While still squeezing the upper radiator hose put the cap back on with your other hand. Ive always done it like that on all my Hondas and never ever had a problem. Ive never drained the block on a s2k unless it was a complete overhaul or something
Old Jul 11, 2013 | 04:45 PM
you need 2 gallons of honda type 2 fluid.. most report no extra fluid when using the block drain
Old Jul 11, 2013 | 07:20 PM
darcyw's Avatar
don't worry about the block plug.
https://www.s2ki.com/s2000/topic/998...#entry22254870
in addition to Billman250's posts, as he is the guru.
good luck
darcy
Old Jul 12, 2013 | 09:11 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I stopped removing the block plug because only a teaspoon comes out. Just leave the radiator draining until its dripped dry. Few hours.
IF you pulled the block drain plug, a small amount of hondabond (or permatex grey rtv silicone) on the threads close to the seal washer is best.
I've added some edits to the bleed procedure in Darcyw's link above.
Old Jul 12, 2013 | 12:31 PM
EELPIE's Avatar
Thanks for the replies everyone. Billman, thanks for the info. I really do not like to disassemble and reassemble aluminum assemblies if I do not have to. One less opportunity for a future leak.
boyguan
May 31, 2015 10:57 PM
wwevo8
Oct 25, 2013 07:29 AM
9kred
Aug 13, 2013 03:07 PM
johnanderson
Sep 7, 2008 05:33 PM
TookayS2K
May 24, 2008 04:32 PM
