Coolant leak
Old Dec 2, 2017 | 08:57 AM
AUaviator's Avatar
Default Coolant leak
I have a coolant leak I’m trying to diagnose. The leak seems to be coming from the passenger side of the engine block closest to the cabin. I took off the heat shield for a picture. I have a good size puddle under the car about the surface area of a footprint every time I turn off the car. Anything special I can check before handing it to a shop/pull the block?
Old Dec 3, 2017 | 01:15 PM
rudyy's Avatar
It could be coming from the water hoses next to the battery and the firewall. Have you checked those hoses in that area? And how bad is the leak? Reservoir tank gets empty completely?
Old Dec 9, 2017 | 09:00 AM
AUaviator's Avatar
i have checked the hoses and they are all dry. I just topped off the coolant (it was 2 quarts low) and as soon as I did, the leak came back without even trying to turn it over. The leak is slow and constant when off and gets steadier when running.
Old Dec 9, 2017 | 09:28 AM
zeroptzero's Avatar
I've had the odd leak on my car, like all fluids the leak can actually start a few feet away and travel down various engine and chassis parts before it drops to the ground. Best way is to jack up the car on 4 stands, get under the car with a bright light and you will surely find the source. Mine have always been loose clamps/hoses with slow drips on older Honda hoses and tension clamps , but there can be a number of sources, get under the car and you will see what's going on.
Old Jan 28, 2026 | 07:00 AM
AL3XIS2k's Avatar
did you ever find the issue?
eld101
Jun 5, 2017 02:50 PM
Gernby
Oct 29, 2013 10:40 AM
Alistair
Jul 17, 2010 08:29 AM
krnmike
Dec 8, 2008 03:37 PM
wildcardtrd
Nov 20, 2006 04:03 PM
