Coolant leaking from weep hole
Old Mar 2, 2014 | 08:16 AM
Crobin_1's Avatar
Default Coolant leaking from weep hole
My water pump is starting to leak coolant from the weep hole. I replaced the water pump when I did the rebuild and it only has about 1200 miles on it. Its a Beck Arnley pump.
Should I be looking at another reason for the failure or just a crappy pump?
Old Mar 2, 2014 | 08:48 AM
MM3Kwolik's Avatar
Crappy pump. If it's leaking from the weep hole, then the shaft seals are leaking-plain and simple. Only buy OEM water pumps from Honda. Lesson learned?
Old Mar 2, 2014 | 08:55 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Longevity of the OEM Honda S2000 water pump has been phenomenal.
Less then 1% failures ever reported here. Many are over 150k miles.
Old Mar 2, 2014 | 09:28 AM
Crobin_1's Avatar
Yes, lesson learned. Thanks guys. Guess I'm shopping for an OEM water pump today
Glad I caught it before other things happened
buzz944
Jul 27, 2011 05:00 PM
kane.s2k
Sep 5, 2010 05:52 PM
ATL_S2K
Oct 21, 2009 07:41 AM
