Replacing the check engine light
Old Feb 22, 2014 | 06:33 PM
cranked911's Avatar
Default Replacing the check engine light
Hey guys, recently I had to get my car smoged and it failed the check because the check engine light was burnt. Any body know how hard it is to replace the bulb under the dashboard? Is it a lot of work to pull it apart? Also where would I get the replacement light bulb?
Old Feb 22, 2014 | 06:54 PM
Utah S2K's Avatar
www.qube-engineering.com has detailed instructions (lower right on website support/documentation). Art makes an LED set for the car and his instructions will get you to through removal and replacent. Not a bad job if you have basic mechanical skills. You can get bulbs at your dealer or any parts store.
Utah
Old Mar 1, 2014 | 03:53 PM
05thumper's Avatar
I would be worried about how/why it burned out. Did you buy used? Did it ever work?
Old Mar 2, 2014 | 03:31 PM
cranked911's Avatar
Yeh I bought the car used. Car didn't put out a code during the smog check. It lit up while starting the car before, but I didn't notice it burned out until the smog check.
beefystud
Oct 28, 2016 09:13 AM
Saki GT
Jan 18, 2012 05:58 PM
Psicho54
Jan 24, 2007 09:40 AM
FearlessFife
Apr 28, 2006 10:04 AM
gochuxsaurus
Aug 10, 2005 07:37 AM
