coolant a little low
Old Jun 27, 2008 | 03:19 AM
ap12ap2's Avatar
Default coolant a little low
I noticed that my clooant level is just a hair below the low marker on the plastic container under the hood. Is there some special coolant i need for this car? will just water be fine? will the walmart 50/50 mix variety be acceptable? Should i get it fully flushed (2004/w 15.5k miles)?-thanks
Old Jun 27, 2008 | 06:32 PM
ap12ap2's Avatar
I bought a jug of formula II coolant from honda today and it is blue. The coolant i have in my my04' is green, is it okay to mix the two?- im not sure what coolant is in the car right now because it came like that when i bought it. Thanks.
Old Jun 27, 2008 | 07:56 PM
icemans2k02's Avatar
the is an overflow resvoir, dont think your low because of that. open up the radiator cap and fill up there if you think you are low
Old Jun 27, 2008 | 08:07 PM
JackS's Avatar
Color is meaningless and can be mixed. Prestone 50/50 for all makes and models foreign and domestic might save you a trip to the dealer.
No doubt there are others but you'd have to check first.
Old Jun 27, 2008 | 09:59 PM
Rdizzle's Avatar
Just make sure the coolant you use is safe for aluminum engines. Use a 50/50 mix (not just water). When in doubt, buy the coolant from Honda.
Old Jun 28, 2008 | 03:51 PM
jelliotlevy's Avatar
The official Honda coolant is only about $12 per gallon. In more than six years of ownership, living in the warm South Carolina climate, I have found that the overflow reservoir loses in the neighborhood of six ounces of coolant every few months. I think that is simply normal evaporation from a nonpressurized storage vessel.
Old Jun 30, 2008 | 10:40 AM
vtec9's Avatar
The coolant system is supposed to be completely closed, and free from loss.. but the overflow reservoir is most likely not air tight. You can top off 50/50 with aluminum safe coolant and water, or just spend a bit extra for Honda type II pre mixed.. No reason to flush it
Old Feb 2, 2009 | 10:25 PM
LegendaryHarry's Avatar
bringing back an old thread but figure it save space.
my overflow is also low. will toppping it off with distilled water be okay?
Old Feb 3, 2009 | 05:20 AM
If it's just a few ounces, it is not likely to do any harm. You will still be pretty close to the 50/50 mix of ethylene glycol and water which is the optimum.
Old Feb 3, 2009 | 10:06 PM
id say since i got the car with 34k on it in 07 ive had to fill it one other occasion. i filled the overflow that time from min to max with distilled water.
still okay to do that?
