coolant refill
Old Jul 24, 2005 | 03:34 PM
xenosis's Avatar
Default coolant refill
ive noticed today that my coolant level was kind of low. not knowing anything technical or mechanical, i am askin a question.
is it ok for me to just pour in any type of coolant with out flushin out?
Old Jul 24, 2005 | 03:51 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
With a MY2000, drain it. It's time.
I've found if you let it run out of the radiator overnight, most of the cooling system will empty itself. After pulling the block drain, a tablespoon at the most came out. So do the rad only. The drain is easy to get to, look straight down between the fans.
So....if you look inside the radiator with a light, and you don't see any white-ish scale, and it looks clean, refill it with Type2 Honda premix. Don't flush it. Most water will do more harm than good by starting the corosion process.
Top off with Type2 as well if you're not going to change it. But change it
Old Jul 24, 2005 | 03:56 PM
xenosis's Avatar
thanx man, its a good thing i asked.
one more question. where can i get some of the Type2 Honda premix?
dealership?
Old Jul 24, 2005 | 03:59 PM
Billman250's Avatar
Top Answer: 1
You bet. Ask for Type2 Honda premix. It's blue
Old Jul 24, 2005 | 04:48 PM
xviper's Avatar
HOLD ON! And Billman can slap my pee pee if I'm wrong.
A year 2000 S2000 does not have Type II coolant. It was the only year that didn't. Plus, it was only good for about 3 years, unlike the original Type II in the later cars, that was good for 10 years (so Honda claims).
Do as Billman says about the change. It's time and long overdue. If you are going to change to a "long life" Type II, it might be wise to flush it well as the two are not compatable with each other.
If you are only going to top it up till you get a chance to change it out, then just add water for now or use "regular" (green, non-premixed) coolant (NOT the long life stuff - Honda Type II or the aftermarket orange stuff).
Old Jul 24, 2005 | 05:10 PM
Billman250's Avatar
Top Answer: 1
Good point....My only concern is with putting water in the system, as it starts corrosion. If that's the case, some Polland Spring will make a nice flush
now let me quote Xv: HOLD ON AGAIN!
The reason I came back here to post....the s2k cooling system is very difficult to bleed. Even if you follow the helm's to the T, you will still have air in the system, and wind up overheating the car. I have my own methods, but I would recommend vaccuum filling the system.
If your heat blows hot, you know you got the air out
Old Jul 24, 2005 | 05:27 PM
xviper's Avatar
I used distilled water for the flush.
Yes, it's a bugger to bleed but the Helm instructions seem to work well if followed. I didn't have to add much coolant after the system "burped" itself and I got heat immediately. I also disconnected the coolant line at the oil filter. No way I was going to get that block heater unscrewed.
Old Jul 24, 2005 | 07:41 PM
oakfloor's Avatar
Well.. that changes everything, as the pre-mixed is what I have in my 00'. and I thought I saw it recommended on this forum? so now what do I do? Its been in for two years now. where does honda say not to use it?
Old Jul 24, 2005 | 08:48 PM
xviper's Avatar
It doesn't say to NOT use it as long as you flushed out all the old coolant. What you don't want to do is mix "regular" coolant (what's in the '00) with Type II (which is longlife). The two will form a gel and could cause problems.
Like I said, MY2000 was the only S2000 that did NOT have Type II coolant. For MY2001 and later, Honda started to use the longlife stuff.
See Helm manual (2001 S2000 service manual) pages 10-8 to 10-11.
Old Jul 25, 2005 | 02:05 AM
03s2kman's Avatar
i have a MY03 and my stuff looks green from the factory? did they change the color of the type II fluid from green to blue?
