Coolant Small Bubbles
It helps to park the car on an incline with the front of the vehicle higher than the rear.
Good luck!
Read this thread thoroughly and follow the instructions provided. Billman is a longtime S2K mechanic and guru. His procedures will never disappoint!
https://www.s2ki.com/forums/s2000-un...bleed-1067218/
This may be a dumb question but, I don't need to flush out the coolant in the system and re add new honda coolant correct? I can just buy the same honda coolant I used and open up the radiator cap and fill as needed to check for bubbles?
Did you open the bleeder while adding coolant (engine cold and turned off)?
Here's my process which has been bulletproof for me.
Assuming the car is already parked on a flat surface or nose up on an incline.
I turn the key on (engine off) and set the heater knob to full hot and wait til I hear the blend valve completely open.
Shut off the key
Insert coolant bleeding funnel.
Crack open the intake manifold bleeder AND the heater crossover bleeder (rubber cap).
Fill the coolant via the funnel.
Keep filling until a solid stream of coolant comes out of each bleeder and cap/close it when that happens.
Fill the funnel about 1/2 to 3/4 way up with coolant.
Fill the overflow reservoir to its full mark and cap it. Make sure the overflow cap tube is on and is submerged.
Start the car and run the heater at full blast. Monitor the coolant temp gauge to make sure the car never overheats.
Wait for bubbles to stop. Wait for hot ass heat in the cabin.
Turn off the engine, remove the funnel and cap the radiator
Go for a short drive. Make sure the heater is blowing hot and the car isn't overheating.
Park overnight.
Wait for it to cool.
Check the reservoir level and top off as needed.
Check the radiator level and top off as needed.
Confirm hot heat and proper coolant temp on your gauge on the next drive.
Shut off the key
Park overnight.
And by hot ass heat, he means hot ass heat. Put the back of your knuckles about an inch or so in front of the vent. It should start getting uncomfortable to hold them there when it reaches the right temp. Then you have hott ass heat
A lot feel good warm air and think it is good only to find out after driving there is still air in the system.
It should not take any driving around or repeating if you bleed it thoroughly the first time. I have never had to repeat the process once I did it all the way through.
A lot feel good warm air and think it is good only to find out after driving there is still air in the system.It should not take any driving around or repeating if you bleed it thoroughly the first time. I have never had to repeat the process once I did it all the way through.
Yep I pretty much start off with the Billman method to get the bulk of the initial air out but put the funnel on for the last part and just let it go. does a great job. Plus, it is a great funnel for filling coolant in general.
