Coolant smell
About two months ago I replaced a couple small coolant hoses (thanks to a rodent). I refilled the coolant and bled the system as per Billman. Everything works perfectly. However, once the car gets hot, I smell coolant. The car has not lost a drop of coolant, I can't find a leak anywhere, nothing is wet... but I smell it.
Any ideas?
Any ideas?
Check the end tanks on the radiator for cracks. I had one on my radiator that would only open enough to release steam. The usually run horizontally the length of the cap, and occur around the hose fittings. They will look slightly white and numerous.
