Coolant Usage or Coolant Leak?
Old Mar 9, 2007 | 10:48 AM
JackS's Avatar
RE-torque your head. This could be the problem. Should be done anyway.
Old Mar 9, 2007 | 10:52 AM
jyeung528's Avatar
[QUOTE=JackS,Mar 9 2007, 11:48 AM] RE-torque your head. This
Old Mar 9, 2007 | 10:55 AM
jyeung528's Avatar
Originally Posted by silencertk,Mar 9 2007, 11:27 AM
the water pump pumps the water hence ---> water pump lol. just kidding. but seriously it pumps the coolant through the system and is belt driven i THINK.
anyway, if it where faulty i.e. leaking you would be loosing coolant. Usually you can find some "corrosion" on the pump housing if its leaking.
i would assume the water pump is fine, a leak would be noticeable/spottable.
at the same time, i don't see any leaks around the head gasket...?
if it was coming through the head gasket, wouldn't I be able to see marks?
if it was leaking into the cylinder, then I wouldn't be able to see anything correct?
How does coolant leak into the cylinder? through the head gasket?
Old Mar 9, 2007 | 11:02 AM
JackS's Avatar
Use a torque wrench and make sure the head bolts are tightened to spec.(don't over tighten).
Old Mar 9, 2007 | 11:19 AM
jyeung528's Avatar
i just talked to supertech (mechanic at honda dealership)
he said in 2 months time, even 1 months time, going from MAX to MIN is just water burning off.
he says a cylinder leak, or head gasket leak would leak much faster than MAX to MIN in 2 months.
his advice is to just top it off with more coolant/water and if it leaks at that rate, i'm fine.
Old Mar 9, 2007 | 11:20 AM
jyeung528's Avatar
OH...IF you can tell me the torque spec for the cylinder head bolts!!!! i will be utterly amazed.
the helm's manual says to torque it to 22 lb/ft, and then 1/4 turn....and another 1/4 turn.
if only you can tell me what that SPEC is!!!!!
Old Mar 9, 2007 | 11:33 AM
JackS's Avatar
geez ,I don't know but since you know, why the question?
Old Mar 9, 2007 | 11:36 AM
jyeung528's Avatar
I don't know what the spec is.
22 lb/ft, 1/4 turn, another 1/4 turn...
what is the spec in lb/ft?
you were probably talking about pulling the cylinder head off and reinstalling a new head gasket and re-torqing the bolts?
or did you mean to just tighten it MORE to spec? if this is the case, i have no idea what the spec is.
Old Mar 9, 2007 | 11:53 AM
JackS's Avatar
Pulling the head and installing another gasket is the last resort.
Due to expansion and contraction the correct torque at installation may have changed. Put a torque wrench back on the head bolts and make sure every one of them is at 22lbs as indicated in your Helms.
Old Mar 9, 2007 | 12:01 PM
JackS's Avatar
Since I don't know the context of your Helms, I'd assume that you arrive at 22lbs in quarter turn increments. This would not be 22lbs plus a quarter turn.
Tighten the bolts in a star pattern avoiding a possible warped head.
