CR Alignment Settings?
Old Jul 14, 2009 | 10:24 AM
Hakkaboy's Avatar
Default CR Alignment Settings?
Does anyone have the full settings for camber/castor/toe for a factory CR?
so far in my search on S2Ki, i've found the following 2 comments
The CR alignment looks like it should wear the tires out slower than the regular AP2 or AP1 alignment. IIRC, the CR specs only 5.4mm of toe in for the rear vs. the 6mm for stock AP1/2.
I believe the CR is -.7 camber in the front and -1.8 in the rear. This should be with you in the car, of course. Good luck.
Does anyone know for sure?
thanks in advance
Old Jul 15, 2009 | 09:07 AM
Hakkaboy's Avatar
anyone?
Old Jul 15, 2009 | 12:49 PM
INDYMAC's Avatar
They should be listed in your owners manual. Have you checked?
Old Jul 15, 2009 | 01:50 PM
Hakkaboy's Avatar
i don't have a CR?
...assuming that it is different from a normal AP2
Old Jul 15, 2009 | 04:20 PM
negcamber's Avatar
Search worked for me...hit it in the first thread from "CR AND Alignment".
Only difference is rear toe:
CR model: 5.5+/- 2mm. (0.22+/-0.08 in.)
Old Jul 15, 2009 | 07:57 PM
Hakkaboy's Avatar
thanks, i made the mistake of searching this sub-forum only, so thats why there were such limited results
but i know what to do for next time
turbo8765
Jul 19, 2011 03:51 PM
HiRpmVTEC
Mar 3, 2010 12:55 PM
Saki GT
Feb 19, 2009 09:28 PM
RadioZero
Jan 9, 2008 08:14 PM
