Cracked clutch disk
Some BG, i went to a shop 40k mi ago that turned out to be very very shady, they left off bunch of bolts, used NO grease at all, just shady shady place. Had to get the competition service rep on phone to tell them they had the right clutch
I want to know what i need to replace, what could have been the culprit of the cracked disk at the springs so it wont happen again(will get pics).
Now i know i will need to replace the:
Clutch
TO bearing
Pilot bearing
Do i need a new (all this stuff has 40k on it:
FW (or will resurfacing do fine?)
PP
Anything else i am forgetting?
Thanks guys
Clutch
TO bearing
Pilot bearing
PP
Thanks guys
Since you already have it apart, visually inspect those parts. If the FW doesnt have burn marks or deep scratches it'll probably be fine to reuse. I think the PP has the same criteria, plus the "fingers" need to not be worn.
If I remember correctly stock disk with a higher force pp will hold 350whp
Stock clamping force is 1800 and Comp Clutch is 2200 on all of their plates across the board I had an email confirming this straight from CC
Short answer to your q of will it hold depends on your power goals
Never EVER launched, or beaten on. Car has perfect compression across the board. I take excellent care of it.
The thing that has me confused is this happened at 20mph in stop n go traffic.
Like i said the shop did a very sketchy job on the install however that shouldnt be reason for it to blow.
No crazy gains maybe just a s/c setup and a nice safety net for whatever breaks as a result lol.
Thanks.
Thanks.
It just happens. That small tab of metal is the only thing that keeps the springs in place, and the springs compress every single time you start off, or punch the gas. It's a high fatigue point. As long as the rest of the components don't look beat up, or gouged from the break, you can just change the disk, pilot, and release bearing.
If the pp and fw are smooth looking, just knock the shine off of them with a medium sandpaper.
