crank pulley removal
Old Feb 28, 2006 | 03:10 PM
Quivers's Avatar
Banned
Default crank pulley removal
anyone know if the crank pulley is righty tighty or does it spin off the opposite direction?
Old Feb 28, 2006 | 03:17 PM
xviper's Avatar
It's a "standard" type of thread (lefty loosie). It just takes an immense amount of torque to get it started (up to 500 lb/ft).
Old Feb 28, 2006 | 04:15 PM
r_duff's Avatar
rediculous torque it takes, yes.
Old Feb 28, 2006 | 05:00 PM
Quivers's Avatar
Banned
I just bought a 710 lb impact and heated the shit up and it still wont come off.
Old Feb 28, 2006 | 05:25 PM
xviper's Avatar
Try squirting it with Liquid Wrench and let sit for 1/2 hour and try again. How do you get an impact wrench in there? I found there was not enough space. Ended up using 4 foot long breaker bars.
Old Feb 28, 2006 | 06:38 PM
gomarlins3's Avatar
Is someone putting on a SC?
Old Feb 28, 2006 | 06:45 PM
spider2k's Avatar
Active Streak: 30 Days
are you using the right tools? the pulley was the easiest part of the install for us.
two 1/2 inch ratchets, one on the holding tool and one on the pulley bolt, with two 3' pipes and one good yank was all it took.
Old Feb 28, 2006 | 07:06 PM
Slows2k's Avatar
An impact wrech can fit with a 4" extension and a deep socket I believe. The problem is too much power is lost though the extension and socket to break the bolt loose.
Even on Honda's where you can use a short socket with an impact wrench you're not gauranteed the impact wrench will loosen the bolt.
Crank holder and a 3-4ft pipe on a 1/2" drive braker bar works everytime. (as long as you've got some upper body strength)
I've picked other technicians off the ground breaking crank bolt loose using a pipe on the breaker bar. Leverage at work, it's a beautiful thing.
Old Feb 28, 2006 | 07:13 PM
John_Z's Avatar
I cheated and used a 6ft section of iron pipe. Came right off
Old Feb 28, 2006 | 07:38 PM
Billman250's Avatar
Active Streak: 120 Days
Top Answer: 1
In any case I think the crank pulley holder is a must.
