Crankshaft thread
Old Dec 5, 2013 | 10:47 AM
jh84's Avatar
Default Crankshaft thread
Is the thread on crankshaft that holds pulley normal lefthanded? (opens counter clockwise)
Just want to make sure, bolt seems to be pretty stuck.
Old Dec 5, 2013 | 10:54 AM
MM3Kwolik's Avatar
Yes, it's regular threads. You will need the Honda (or Honda equivalent) hex holding tool with 1/2" breaker bar to wedge against the subframe and then a large 3/4" breaker bar with a 19mm socket to get it to come off. You are guaranteed to break a 1/2" breaker bar if you try using that with a pipe. (I've tried and failed multiple times.)
Old Dec 6, 2013 | 11:04 PM
myhui's Avatar
Spray penetrating oil on the bolt first, let it soak overnight, spray it again, then try turning the bolt.
Don't try to turn it when dry.
S2k_razy
Mar 1, 2015 12:31 PM
patinum
Jun 25, 2006 09:21 PM
RED MX5
Nov 13, 2005 06:54 PM
hyedracyl
Dec 4, 2004 11:10 AM
