Crashed at track, ABS Code List?
Old Aug 19, 2020 | 06:24 PM
weenrock's Avatar
Default Crashed at track, ABS Code List?
Hey my dudes,
I crashed my race car at the track at a NASA time trial race. I hit a barrier head on. I'm fine, but the front of the car is smashed all the way up to the radiator. Engine still runs and I am planning to get the frame straightened at a shop. In the meantime, I am pulling all the codes to see if I need more parts. No CELS, but I got a bunch of ABS codes when I used the jumper for Pin 4 and Pin 9 method and counted the ABS blinks. Some I was able to figure out, the others I could not find a reference for. I searched in S2ki and Google. Nothing was found on 25-86.
ABS:
  • 12: Faulty right front wheel sensor pulse signal
  • 14: Faulty left front wheel sensor pulse signal
  • 16: Faulty right rear wheel sensor pulse signal
  • 18: Faulty left rear wheel sensor pulse signal
  • 25: Unknown
  • 26: Unknown
  • 65: Unknown
  • 83: Unknown
  • 86: Unknown
Steering
  • 23
Any help translating these codes would be most appreciated!
Old Aug 20, 2020 | 02:03 AM
flanders's Avatar
Most of them might clear by them self if you just could drive it.
The wheel speed sensors are pretty easy to check function if you just spin the wheel by hand while measuring the output from the sensor.
Glad you are ok and hope you get the car sorted
Old Aug 20, 2020 | 11:45 AM
weenrock's Avatar
Thanks man! That is what I am thinking too. Some of the wheel sensors cables are pinched in some of the frame that crunched. Worst case scenario, I just need to swap them. I'll try clearing them but I can't drive it until the frame is fixed.
here is the wreck
Old Aug 29, 2020 | 12:43 PM
zeroptzero's Avatar
That sucks. Did you hit a patch of oil on the track, it seemed like an odd place to spin out. Good to hear you were fine, and the car can be repaired. Less weight now without the pass. airbag, lol.
sevca2308
May 15, 2016 08:35 PM
Saki GT
Apr 11, 2016 09:49 AM
2004TurboS
Apr 11, 2016 07:15 AM
Redsox01
NYC Metro Stock Exchange
Feb 20, 2016 08:59 PM
