This is crazy, but Oil Burn? The Story of conquering phantoms.
#21
#22
Im sorry, it was no one in this thread. I removed all my content from the forum.
But the gist was measure crankcase pressure, it should be close to -11 to -14hg at idle. if it is less, you have a crank case leak likely. check all areas that OIL and AIR are, this pretty much limits it to all gaskets on the valve cover, and front timing cover. High pressure gaskets like vtec or the like, or sump gasket(oil pan) are unlikely to leak significant pressure without there also being a massive oil leak. Weeping oil, and crankcase pressure are what you should look for.
FRM doesn't like to seat rings like IRON sleeves. so maintaining crankcase vacuum is necessary to keep the rings fully seated and minimize oil burn. The original post commented on the similarities of Oil burn being minimized when installing KrankVents. The common denominator between posts on the forum of people minimizing oil burn - crankcase vacuum to effectively seat rings during stroke. Leading to believe the PCV system is undersized, OR since new significant crankcase vacuum leaks have formed causing the PCV to not run as efficiently as Honda intended.
Again sorry, it was no one in this thread. I simply used a Python script to delete all of my posts across the forum
I tend to approach these forums as a learning tool -- I learn something new here, save myself a ton of money, and try to pass on knowledge and help others with the hope that they'll pay it forward. Not everyone does, but all it takes is one.
#23
Not going to ask why you thought removing your content was a good idea, or if you have beef with someone specifically, but some of your posts would definitely have been beneficial to some people. Not everyone on here is bad. Really wish you wouldn't have removed them, but oh well.
#24
We surely don’t need to lose great members and their content due to immature response/content. This forum will never be allowed to resemble FB.
Please PM/link me to any content that may be objectionable in the UTH forum and I will be happy to review/delete it.
#25
I'm going to add to this, While I minimized oil consumption as notated above. It has been even further minimized. I switched from an 00-03 Valve cover to an 04-05 AP2 valve cover - but using the TSX PCV
My S is seeing about 1/5th quart every 2k with heavy driving after doing all of the above previous posts. A very big difference from 1qt every 300-700 miles depending how hard I drove. Sitting with 223,185mi, on original block and head.
#26
I agree with the post above, I did the same minus the tsx PCv. I use to burn 1 quart per 1000 miles. Now I burn almost nothing. I changed all gaskets on valve cover to new also and use valvoline full synthetic. 2002 83k miles
#27
My compression tester has an adapter nozzle for vacuum lines but I am not 100% sure which line to use
Probably the one coming from the intake tube...?
#29
yes you can check vacuum from the front breather while the engine is running at idle. opposing that, you can block off your pcv or ensure its functional first with the engine off and put 3-5psi into the breather to listen for air to find leaks in a quiet environment
nubbel (01-02-2019)
