Creaking Noise
Old May 31, 2016 | 04:45 AM
Wojofoo's Avatar
Default Creaking Noise
https://www.youtube.com/watch?v=XOebYiuTe6M
I've had the noise in the video happen twice now.
Both times the car has been parked on a slight incline and the only way to reproduce is bounce up and down within the car. Sideways movement doesn't make any noise.
I also think both times the car had been stationary for a few days.
Anyone have any thoughts on what this could be?
Old Jun 3, 2016 | 06:12 AM
AE_Racer's Avatar
I have noticed this in other cars before. Probably something to do with gravity binding up the suspension with the ebrake being on.
Im sure someone could explain it a little better.
Old Jun 6, 2016 | 05:50 PM
Forziii's Avatar
Mine does this too.. but as AE said, I think it's just the e-brake.
Try putting it into gear and let it sit on the gears and try it. it won't make the noise.
Or try pulling the e-brake tighter and it may not make the noise
Old Jun 6, 2016 | 06:19 PM
jayok's Avatar
ARB droplinks. They run dry and creak like hell. Get it when taking off or slowly over uneven ground. To test disconnect the links temporarily. (Although could be rusted)
Old Jun 6, 2016 | 06:25 PM
zeroptzero's Avatar
Your e-brake needs tightening, the car is inching ahead slightly when you do that.
Old Jun 8, 2016 | 06:22 AM
Slowcrash_101's Avatar
I had a squeak too, turns out it was coming from the door, greasing some stuff up and putting some foam padding to stop the passenger door liner from rattling did the trick.
jWESTFOO
Mar 31, 2014 06:59 AM
TerminatioN
Apr 6, 2011 08:23 PM
s2kdriver80
Jan 21, 2009 12:04 PM
Stiggywig
Apr 21, 2008 07:20 AM
Suave J
Feb 11, 2001 12:08 PM
