Cross Threaded Seat Rail Bolts
I overtightened the bolts that hold the rails to the floor, looks like the tips are damaged. Will running a chaser tap to straighten the threads in the hole and a chaser dye on the bolts be a good fix (if it works) or should this be a temporary fix only?
thanks guys.
thanks guys.
Actually , I did the same thing a couple of months ago. There is some play in the bolt so I'm going to have to get it tapped. Thanks for reminding me.
Sorry, I'm no help, but bump for some answers
Originally Posted by RedY2KS2k,Sep 13 2006, 02:43 PM
Did you cross-thread (thread title) or overtighten (thread text) them. There's a difference and it matters.
thanks.
a little bit lose?...
If you cross threaded, you only got the bolt a few rotations in before it got too crooked. In which case you probably messed up the top few threads. You could probably get away with just chasing the threads with a tap.
If you overtightened, that means the bolt threaded possibly all the way down and all the threads are stripped. You can't chase this with a tap. You might be able to helicoil it, but I don't know if the material is hardened or not???
i will give the chase tapping/die a try tonight and see if it works. thanks
