Cross-threaded Spark Plug
Old Oct 26, 2005 | 09:36 AM
icethug81's Avatar
Default Cross-threaded Spark Plug
I was changing spark plugs on my s2k recently and found one of the spark plug was installed incorrectly causing cross-thread in where spark plug goes in........what's the best way to fix this problem? rethread? helacoil? or do I need to change the whole head? please HELP~~~!!
Old Oct 26, 2005 | 03:39 PM
VAD's Avatar
VAD
A new head is the only sure-fire solution. I'm not sure if I'd trust a heli-coil.
Old Oct 26, 2005 | 06:47 PM
S2KPUDDYDAD's Avatar
Please
get a spark plug chaser, if you don't know what that is, go to a parts store and ask an older worker/parts guy there and they will help you.
This was/is a common problem with aluminum heads and people who man handle a socket wrench.
Remember This is something we did on old Chevys I would say that xviper would know more of how tolerant the F-20C is to do it this way "old school" good luck
Use the chase to cleanup the threads and at your own risk turn the car over a few times with the plug removed and other coil packs removed as well. This is to blow out any metal in the cylinder. It is what we did on big block Vettes and Cameros back in the day that had aluminum heads with improperly installed plugs.
I never had any go wrong
Old Oct 27, 2005 | 04:46 AM
chris_barry's Avatar
Search on posts for "Time Serts".
I posted details a long time ago on a technique that uses shaving cream in the cylinder to prevent swarf falling into the cylinder when installing a timesert. The timesert is a solid collar with threads on inside/outside that is expanded to repair the thread. The kit comes with the tooling to install it.
Good luck
Chris.
Old Oct 27, 2005 | 07:39 AM
icethug81's Avatar
Thanks for all the replies~
Right now, I was able to install that spark plug in (it doesn't go all the way in but fortunately, it fit in tight and seems like there's no power loss or missfire) and runs great as before. But I guess I'll find someone with long experience with car who can fix that thread for me. I think I'll go for the chaser to fix the thread first and if it doesn't go well, I'll try timesert. AND if that doesn't work neither, I guess I'll just get a new head.......ah~~ expensive way~~~
anyone with used FC20 engine head~?
Old Oct 27, 2005 | 10:50 AM
dhayner's Avatar
[QUOTE=icethug81,Oct 27 2005, 07:39 AM]Thanks for all the replies~
Old Nov 6, 2005 | 08:45 PM
AnthonyB's Avatar
I have a problem with my engine. I replaced the Cams and rocker arms. And the car wouldnt start at all after i did.
I have the head with all the valves and vale springs. It doesnt have the rocker arms and cams. It has a timing chain.
Anyone out there knows why it isnt turning over? IT tries to. But fails.
Thanx
Anthony
Paperboy7777
Jan 9, 2012 09:23 AM
speakeasy2009
Aug 28, 2011 06:17 PM
essi1553
Aug 22, 2010 04:15 AM
mikitymike55
Jan 4, 2008 09:27 PM
