cruise control delete/bracket mod
I never use my cruise so i figured why not take it out and have a little better looking bay. I read up on it real quick in some other threads and got it done in maybe an hour. i work pretty slow. anyway i removed the cruise control and modified the bracket that holds it and the overflow tank. came out pretty nice. simple mod for anyone thinking about it.
3 bolts to take the unit out, then 2 for the bracket, also pop the overflow tank off and lay it aside
heres the little template i made to eliminate the cruise portion but keep the tank holder
little work with an angle grinder
smoothed out sanded and painted, looks pretty clean!
yep I removed it. if you unbolt the pedal bracket two 12mm. You can see the pin that goes through that has that little arm on it with the spring. There is a flat washer that holds it on, you have to use something very thin to pry it up, I used a razor blade, wedged that in, then used a thin screwdriver, and so on until I could fit a long screw driver in there and pry it off.
XxMerlinxX
Sep 30, 2014 08:22 AM
