Cruise Control Removal
Old Mar 16, 2009 | 05:34 PM
  #21
leets's Avatar
Banned
Originally Posted by zacs2K,Mar 16 2009, 03:36 PM
thanks for the help on the coolant resevior, ill prolly do that.
Can I just use a bottle or something as a coolant resevior? I want to do something custom.
Also I have the cable disconnected from the pedal assembly, I just need to get it through the firewall.
You can use virtually any container for the reservoir, just as long as you have it set-up properly.
If I remember correctly, I also had some trouble routing the cable through the firewall. It's been awhile, but I believe you have to push the cable into the cabin from under the hood. It's attached to the firewall grommet so you just need to push that rubber part thru until the whole thing is free from the firewall.
I'm not 100% positive (sorry, bad memory), but hopefully that helps.
Old Mar 16, 2009 | 05:45 PM
  #22
AusS2000's Avatar
ARC (and I'm not usually one to endorse JDM products) do a neat aluminium reservoir and oil catch can that mounts in place of the CC, res and bracket.
Old Mar 16, 2009 | 09:25 PM
  #23
zacs2K's Avatar
how does it have to be set up?
Old Mar 17, 2009 | 07:09 AM
  #24
leets's Avatar
Banned
Make sure it's securely mounted and capped, with the overflow tube submerged. Also, don't forget to take into account that the coolant can get pretty hot, so don't use any cheap, thin plastic.
Old Mar 20, 2009 | 05:27 PM
  #25
zacs2K's Avatar
ok well i got the cruise control out and bought the 06+ bracket to mount my resevoir back in palce. The bracket only cost $10.
before....
After...
Old Jan 25, 2010 | 05:02 PM
  #26
Ilike2DRIFT's Avatar
I just removed My cruise controll and it was a PITA!
FYI, it's alot easier if you remove the driver seat to work under in the foot well. Which i didn't...
zacs2K, did you remove the metal peice on the gas pedal? I removed mine. There was a lock washer which i had to cut off. Also do some grinding with the dremel since that peice was tapered. Then it slid right out. I didn't have to take the gas padel assembly off.
Old Jul 7, 2011 | 12:51 PM
  #27
jsenclosure's Avatar
besides the unit in the engine bay what else is there to remove from the cruise control? Besides the buttons on the steering wheel obviously.
Old Jul 7, 2011 | 01:39 PM
  #28
robrob's Avatar
The steering wheel cruise control switches are wired to the steering wheel's "clock ring," and the wires are pretty short so it's not easy to relocate the switches off the steering wheel. I left the cc actuator cable in place, it wasn't worth the trouble.
donaldmejr
Aug 30, 2011 03:52 PM
21k
Aug 29, 2009 06:10 PM
c17r15
Dec 8, 2005 12:58 PM
mic_crispy
Nov 2, 2005 12:19 PM
