Cruise control surges 4-9mph
Old May 28, 2008 | 02:20 PM
Sleeper2000's Avatar
Originally Posted by negcamber,May 28 2008, 01:57 PM
The one marked Step 5 Clamp T-tap is where I'm having trouble...but note that the blue/white (marked "Crimp female") wire is the speed signal wire and may give a similar problem.
Yep, I've checked BL/W, Y/BL from the transmission all through the kick panel and dash...
I've had no speed compensator or other devices installed, so I have no splices or breaks in my wiring.
Sleeper
Old Jun 3, 2008 | 11:19 PM
Noizemaker's Avatar
OKay. . . so this gets wierd now! Is the S2000 VSS a hall sensor or a geared piece? I did diff, trans and engine oils last night. Today I drove to Seattle. Cruise and speedo worked FLAWLESSLY the whole way.
My only theory I have is that it's a hall-effect sensor in the trans, which leads me to think that there's metal floating in my trans that was flicking past the sensor, screwing it up. ALL i changed was the fluid, didn't touch any wiring, nothing. Trans works okay, but maybe it's time to find a new one if there's random crap floating in it?
Of course, if it's a gear-driven sensor, this theory all goes out the window, so i'd love to know.
Old Jun 4, 2008 | 06:39 PM
Tgr_Ree's Avatar
The cruise control in the S2000 uses a cable. If there is too much slack in the cable, it could cause the speeds to go up or down. I would check the cable freeplay and adjust if nescessary. Hope this helps.
Old Jun 4, 2008 | 10:31 PM
Noizemaker's Avatar
but now it's flawlessly working when all i did was change fluid. The cable's not really freeplaying, it pulls with plenty of force when the car's speed changes (to the computer anyhow.)
Old Jun 5, 2008 | 05:43 AM
kial007's Avatar
Its a hall-effect sensor.
Old Jun 5, 2008 | 06:30 AM
GEARHEAD's Avatar
I've had the same cruise control issue for over a year. I've replaced the VSS which did not fix the problem. I've also swapped the instrument cluster which also did not solve the problem.
A few observations from my specific issue:
- The speed read by the cruise control is fluctuating. Happens so fast that you usually won't see a change on the speedometer.
- I believe the cruise control is seeing these fluctuations and trying to compensate, hence the surges.
- After prolonged driving (1+ hours) my speedo sometimes bounces all over and sometimes drops to zero. I think this is the same issue but for some reason with time (or maybe heat), it gets more dramatic.
- This also affects the power steering as it thinks the car is now going zero mph and ups the power assist - this is an odd feeling when racing at the track and your steering gets extrememly light in a high speed corner.
I also have a yellow box speed compensator but I have un-wired it which did not fix the issue.
Regarding the hall effect sensor and transmission fluid change: I've changed tranny fluid several times with no resolution.
For those with this problem, what transmission fluid are you using?
Old Jun 5, 2008 | 08:06 AM
Noizemaker's Avatar
It is a HES, huh? Craaap. That sucks.
I'm using Honda MTF both before and after the change.
Old Jun 6, 2008 | 11:12 AM
[QUOTE=Tgr_Ree,Jun 4 2008, 06:39 PM]The cruise control in the S2000 uses a cable.
TIGR2
Aug 4, 2016 08:32 PM
abroke1
Feb 18, 2013 10:47 AM
dsthez
Mar 4, 2010 05:36 AM
folex187
Aug 11, 2009 10:01 AM
1FastS2k
Jul 9, 2006 11:36 AM
