cutting door panel for new tweeter!
Old Mar 1, 2013 | 01:44 PM
Princeneo's Avatar
Default cutting door panel for new tweeter!
i bought a new tweeter for my door panel and it seems they are a little bigger than the old ones,now im trying to cut it using the hole drill saw but it doesnt stay on the surface, is there any other tools to cut this thing?any idea ?
Old Mar 1, 2013 | 08:12 PM
xviper's Avatar
A proper hole saw has a drill bit in the middle to keep from "walking". That's not the usual place for the tweeter on an S2000 door.
Old Mar 1, 2013 | 08:59 PM
realblag's Avatar
I would scribe the outline of the hole you want in the plastic and then take a Dremel tool with a sanding drum and enlarge the hole.
Old Mar 2, 2013 | 01:32 AM
CoolGuy094's Avatar
I used a 2" hole saw to cut a hole on the other side of the speaker grille to mount mine. Its impossible to flush mount a tweeter in the OEM location without extensive foam work. You need a flat surface, and just behind the speaker grille area is one of the best flat surfaces on the door panel. What size hole saw did you use? And what size hole saw do the installation instructions for your speakers recommend? I prefer using a dremel tool if I have to bore out a hole just a bit wider, as mentioned above.
Old Mar 2, 2013 | 07:00 AM
CrAzYNeSs's Avatar
Member
If you don't own a dremel. Takeoff door panel set it on a piece of wood. Use the hole saw with the center drill bit, drill a pilot into the wood, and have someone hold your door panel still while you enlarge the existing hole.
Old Mar 2, 2013 | 12:03 PM
Princeneo's Avatar
thanks guys for the help,the door panel is fixed finally, i do not have dremel so instead i used this knife to enlarge the hole.
Old Mar 2, 2013 | 06:05 PM
CoolGuy094's Avatar
Nicely done.
MercGuy
Dec 7, 2015 02:38 PM
Kermit the dawg
Mar 16, 2010 06:27 AM
jetboater
Nov 23, 2005 05:05 AM
Ajjra
Feb 12, 2004 12:51 PM
noTor
Aug 3, 2001 03:50 PM
