Cylinder Head Options
Old Sep 28, 2025 | 02:58 PM
2JayCee's Avatar
Default Cylinder Head Options
Hello everyone,
I recently discovered my motor has low compression in cylinder 1 which explains my misfire and rough idle but smooth driving. Performing a valve adjustment showed that both intake and exhaust valves were extremely tight.
I believe my valves are burned up and leaking and I figure the next course of action is to repair the cylinder head.
I see some cylinder heads local to me and am wondering if it's worth buying a used good one after I test it for straightness and leakdown or sending mine to a shop to rebuild?
Thanks!
Old Sep 28, 2025 | 03:05 PM
cosmomiller's Avatar
Top Answer: 1
Any details of age, milage, previous owners, you know, an abbreviated history of the car?
Old Sep 28, 2025 | 03:16 PM
2JayCee's Avatar
Are you referring to the cylinder head for sale or my car?
Old Sep 28, 2025 | 04:04 PM
Car Analogy's Avatar
You need to do a leakdown test (after valves properly adjusted) to co firm leak is valves, and only valves.
Where you hear air leak hiss, will tell ypu if leak is valves vs rings, and intake or exhaust valves.
If your valves seats aren't really bad, you might be able to just get new valves, lap them, new valve seals just because. You might not need a new head.
Old Oct 1, 2025 | 03:07 AM
starchland's Avatar
Rebuild. Read the service manual
Old Oct 2, 2025 | 04:38 AM
B serious's Avatar
Do the valve adjustment. See if that fixes the issue.
If it does, why rebuild the head? You haven't confirmed burnt valves. So maybe they're fine.
Old Oct 3, 2025 | 04:18 AM
Do VA
Do leakdown test & compression test
Evaluate results
Old Oct 7, 2025 | 10:18 AM
s2krusty's Avatar
When I removed my cylinder head at 200,000 km, the valves were leaking, the exhaust valves needed replacing, the intake valves were at min. of spec, and the valve seats and valve guides were worn. I replaced everything except the valve seats. S2000s run for a lot of miles, but that doesn't mean everything is fine. If you check everything with the HELMs manual, many things will be worn out, out of spec.
Old Oct 8, 2025 | 08:43 AM
2JayCee's Avatar
Performed a leakdown test. I have 27% loss in cylinder one and I can feel air escaping from cylinder 2 spark plug hole. I also can hear air coming from out the back exhausts. No air coming from coolant though.
Old Oct 8, 2025 | 08:44 AM
2JayCee's Avatar
Already did the valve adjustment. Performed a leakdown as well. Air is leaking from cylinder 2 even though I’m leak down testing cylinder 1 at TDC.
boyguan
Jul 8, 2021 10:39 AM
Chance S2K
Jan 28, 2016 07:12 PM
tan0116
Sep 21, 2015 10:44 AM
Poe408
Dec 12, 2011 08:23 PM
mxt_77
Aug 16, 2008 05:19 PM
