Cylinder scratch
Old Mar 13, 2012 | 09:58 AM
BBV S2K's Avatar
Its an 02' Ap1 with 95k right now...
Problem is that spark plug tread went bad and the spark plug fell and piston hit it out of the hole... and some pieces of the coil melted inside and went to the piston... you can feel the scratch but they arent that big... maybe a small honey will fix it?
Old Mar 13, 2012 | 01:32 PM
chris_barry's Avatar
Sacrifice a chicken and put it back together. If it deteriorates further you can fix it properly then. If it runs fine and holds compression just keep up the supply of sacrificial chicken.
Old Mar 15, 2012 | 07:45 PM
BBV S2K's Avatar
http://www.hondaautomotiveparts.com/...ry5=GASKET+KIT
will this kit have all the gaskets I need to put the Head back? or im over doing it and need less?
Old Mar 16, 2012 | 04:25 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Looking at your pics, seems the cylinder walls are only one issue.
You have serious contamination of the cooling system, and the top edge of the cylinder sealing area is eaten away.
The one piston appears to be detonating coolant. I feel you will have major head gasket leak, as you seem to have had one before.
Old Mar 16, 2012 | 10:41 AM
BBV S2K's Avatar
A new head gasket could fix that?
im getting a new one already but just to make sure before putting everything back together... car wasn't consuming a lot of coolant/water it was full always with the car on/off...
slooshie
Jan 13, 2018 09:13 AM
Touge Master
Oct 13, 2010 02:18 PM
AP1FTW
Aug 27, 2009 05:18 AM
customcamry
Aug 5, 2007 02:10 PM
