Damaged front caliper Banjo bolt thread
Hey guys,
I was installing a set of Spoon brake calipers on my 01' S2000 earlier, and I managed to screw something up on the last bolt I had to tighten, the banjo bolt on my right caliper. Either I could not keep the brake-line flat on the caliper because it was a bit twisted or my torque wrench needs a replacement (I was torquing to 34Nm).
But the real problem is that I damaged the thread.
Does anybody know an easy fix to this issue ?
Thanks,
Thanks,
I think the bolts are more likely to strip than the threads of the caliper, try a new banjo bolt from Honda. I know from past experience that those things strip out easy so I torqued mine to 20 ft lbs when I recently swapped brake lines.
Thank you for your answers!
@JFUSION: I wish it was the banjo bolt because I have 2 spare ones. Unfortunately the threads on the caliper are striped
@SilverS2kF22C1: That's what I will do eventually. I was looking for a fix that I could do myself though
Steve P
10-11-2013 08:28 AM
