Dave Emsen
Old May 23, 2017 | 06:58 AM
Emoplugs's Avatar
Default Dave Emsen
Im having a misfire error code come up, coil packs changed and plugs, I am now wondering if it is the coil pack wiring as it only misfires underload, which if I remember back to the old rotary distributor you used to get the same effect with dmp poor spark plug leads - any ideas?
Old May 23, 2017 | 08:39 AM
Manga_Spawn's Avatar
Site Moderator
Which cyl is the code or is it the random one? If it is a specific cyl move that coil plug to another location and see if the misfire follows it. If it does then it is the coil pack. If not it is something else. It could be the injectors. Have you had the valves adjusted? Can't say I have heard of the wiring going bad for the coil packs. Possible I guess but usually the culprits of this are plugs, coil packs, valve adjustment, injectors or more serious a bent valve or something worn in the valve train.
Old May 23, 2017 | 10:30 AM
Soviet's Avatar
X2
Exact codes will help us help you.
If you want to help yourself this is a good resource: https://www.s2ki.com/forums/s2000-un...thread-659930/
Soviet
Jan 26, 2016 01:25 PM
209adrian
Oct 24, 2013 05:03 PM
MSBx03
Apr 2, 2013 04:08 PM
DCs2ooo
May 4, 2010 03:07 PM
Jamison1987
Aug 17, 2009 06:16 PM
