P1399
Old Apr 1, 2013 | 07:41 AM
MSBx03's Avatar
Default P1399
My car started throwing this code yesterday. It only does it on cold start, sometimes so bad the car will actually die. I'm thinking it might be my injectors? Would that be a good place to start? Kind of a vague code.... Any advice on where to start? I jsut recently replaced cylinder 3 coil pack with the '04 part number (REPA504601) if that helps at all..
Thanks.
Old Apr 1, 2013 | 08:48 AM
s2000maniac's Avatar
Start with a valve adjustment, then new plugs, then clean injectors, then do a compression test, then replace coil packs.
Old Apr 1, 2013 | 12:57 PM
jsenclosure's Avatar
try these first
swap a coil pack and see if the code moves cylinders
swap and injector and see if the code moves cylinders
those are the two easiest ways to tell if it's an injector or coil pack issue. if it's not an injector or coil pack i'd do a compression test
Old Apr 1, 2013 | 04:41 PM
Murphg05's Avatar
I had the dreaded P1399 for a while. Mine felt like it was running on 3 cylinders. I did the valve adjust, cleaned IAC, new plugs etc etc etc. In the end in turned out to be a coil pack. A good place to start might be the plug that goes onto the coil. Make sure connections are all good, no broken wires and such. Easiest place to start I think would be the plugs and coils packs. How many miles?
Old Apr 2, 2013 | 06:33 AM
MSBx03's Avatar
About 85k, the only time it misfires or runs improperly is on the first start in the morning. Other than that she runs fine, sometimes the RPM's dip below idle for like half a second whenever I push in the clutch.. But thats it.
Old Apr 2, 2013 | 03:56 PM
alphalanos's Avatar
pick up one of these bad boys it will tell you which wires arent getting spark
Old Apr 2, 2013 | 04:08 PM
Murphg05's Avatar
Valve adjust would be a good place to start if you haven't done it yet. Could be the valves are out of adjustment enough that it misfires until the engine warms up and things start to expand. Keep us posted....
Emoplugs
May 23, 2017 10:30 AM
santiagoa526
Apr 13, 2016 09:34 AM
solitarycheese
Aug 16, 2014 09:07 AM
JLEEzAP2
20
May 6, 2011 01:15 AM
Calamari
Dec 5, 2010 12:49 PM
